Hi
I have a Mini Pro SK17i. Is it possible to password protect the SD Card.
I have Safehouse on my laptop and USBs and it works very well. Can it work on my phone?
Also I am getting very fuzzy photos on the rear camera lens it almost looks as if there is a plastic film over the lens, could this be the case.
I have had a good look but cannot see an edge to the plastic to pull off.
Thanks tdc4266
Pocket secure it's for windows phones, that's why it won't work, what exactly are you looking for?
