Well let me explain you guys my problem
memory card(avaliable before downloading the game) - 2.5gb
I installed a HD game(thought it didnt work and i was dissapointed but that is another story)so when i installed it , it was a 10mb file then when i open it ,it said an additional 110mb needs to be downlaod inorder to play the game and it download almost like 50mb and my wifi connection failed then i checked my memory card and 50mb was already filled up so it was 2.45gb
then when i open the game it again downloaded 110 mb and my memory card now was showing 2..39
and the game also didnt run properly the graphics were all black ..so i unistalled it but still my memory card is showing 2.39gb ?
why is that so ?? help required ?
This would be due to the game's file contents being loaded on to the memory card and not being removed once the APK has been uninstalled.
I can only suggest that you access the memory card and delete the contents manually.
BTW i have xperia Neo V
how do i do that? and where can i find the downloaded contents of the game ??
okay dude i got it ..thanks alot
cheers
It can be done with a PC, simply plug the handset in to a PC via USB and open the memory card within My Computer/Computer.
The folder generally would have the same name as the creator of the application or it will simply be named after the game you downloaded.
No Problem
glad I could help.
