Hello friends, I'm using Xepria Neo with Android 2.4.4. I failed to find out the following in my phone. ๐ NEO
Can we store b'days, anniversary etc in contacts?
Where I can see my memory card data? i.e. what's stored in my memory card?
From Android Mkt, apps directly gets installed or I can find their setup file?
How can I select default storage as Memory Card for all my photos, videos (captured by camera), for files (transferred via bluetooth) ?
I added my google account and by mistakenly click on SYNC PICASSA ALBUM, and my phone has synced it. I do not want my picassa album to appear in my phone's gallery coz my picassa album contains lot of pics and some vulgar pics too. How can I un-sync it?
Thanks in advance!
http://talk.sonyericsson.com/thread/23405
nothing is saved in internal or phone memory except applications
nothing is saved in internal or phone memory except applicationsSo there's no such feature of storing b'days, annivarsaries in contacts ??
just installed File Expert to view my SD card and I am annoyed .. damn.. so many folders.. it also shows system folders and alll .. what if i could delete system folders accidently... I hate such UI to access files & folders
#fail
Thumbs down for this android ๐
P.S.: Kindly correct me if i am wrong
i thought i explained good
ok..
well yes theres no feature..
you have to try another application from the android market to store birtdays etc..
and if you sync your facebook , it will how birthdays in your facebook contacts
ok..
when you open file expert..
select my files and then sd card..
if you delete any of the sd card stuff , it may affect applications etc and not the phone itself so dont worry
mark the correct and helpful answers
yes, you explaid good mate but i asked again coz i could not believe that android not providing such common features of storing b'day, anniversary and all.. crap! fail! thumbs down Android ๐
b'day and anniversary reminders are so singnificant .. damn !!!
well, such basic things I know.. that how to explore SDcard.. in my SDcard folder there are many useless or irrelevant folders to me like android_secure, android, bluetooth, all apps folders, system, pictures, images, videos, music, media etc instead of just simple main folders like PICTURES, VIDEOS, MUSIC, Apps and games. Everything is scattered >_<</p>
HOW to remove synced picassa album from Gallery without removing google account? did you get it?
well yes this is a limitation
Naznaฤite sviฤanje na Facebooku
