I am a proud user of Sony Ericsson Xperia Arc S. Ice Cream Sandwich is a great update from GingerBread and I am loving it! However, I currently have a problem with the Media Shortcut Widget which houses Music, Pictures and Videos. It seems that it takes up a lot more space than usual. Previously, I could put Music Player widget, Photos and Videos Scrollable widget and Media Shortcut widget all in one page, but I can't do that anymore after the update. Please help!
Ooooops, it seems to be a bug
Though you would be able to make it through this trick
Settings > Apps > All > Xperia Home > Clear Data
I wonder how it can fit now after doing this trick but won't if you remove it and try to add again
Good solution. However, I hope there will be an official fix for this bug. I didn't know that by clearing the data, all my widgets will be gone and I have to re-add them again.
Thanks by the way.
