I am trying to install Media Go 2.1 on my newish HP Laptop that runs on Windows 7 so that I can transfer music files across to my new Experia Arc S phone. The installation begins and then fails each time with the following message: "There was an error installing the PlayStation(R)Store".
Unpacking the Media Go Installer
Installing PlayStation(R)Store for Media Go
There was an error installing the PlayStation(R)Store.
Click Cancel to exit.
I have disabled Kaspersky Internet protection and switched off the firewall, but it makes no difference. I also tried installing a lower version Media Go 1.7 and still received the same message.
Many thanks
you know, you don't need media go to transfer music, connect your Xperia S to your computer -> go to my computer -> Xperia S -> internal memory -> Music -> copy paste your music.
Thanks very much. A great answer that worked straightaway and so quick. Much appreciated.:smileyhappy:
Anytime, if you MUST use Media Go, restart your PC -> f8 -> safe mode -> try to install it there.
