I couldnt able to transfer video files from my PC to Mobile. When i try to transfer mp4 videos of 700 MB to my mobile via Media Go but i cldnt able to view the videos which i transfered. it shows an error. Kindly advise how to use Media go and also suggest me any software in the market to convert the video files which is suited for my somy xperia ray.
thanks in advance.
you dont need to convert any video
just connect your phoe to your computer..copy the desired file to be transferred..
paste it in the video ( you can paste it in any folder )
a pop up may show "the file you are transferring is not supported by the device "
but you click on copy anyway
then go to the android market and download mobo player
its the best video player..try it..it will play any video without conversion..try it now
thx, do this player supports all the video format:smileyhappy:
