I think my GPS not working properly after the ICS update. In google maps, it is showing my location approximately 200 metres only which can be done using mobile network.
While i was using ginger bread, google maps were accurate up to 2 metres using GPS.
Also, google maps doesnt show the triangle sign which helps to find out which direction i am facing currently and helped me in navigation. In ICS version, it is showing as dot instead of triangle symbol.
Please help.
Any settings need to be changed?
That sign ( pointer/arrow) is missing
Settings > locations > mark all 3 options
