Hello,
After speaking to O2 for a few days now to send me the Internet and MMS Settings which failed to download each and every time, they have now sent me
1) Internet Settings:
Homepage: http://wap.o2.co.uk/
AP address: payandgo.o2.co.uk
Gateway (I) address: 193.113.200.195
Username: paying
Password: password
Session type: Continuous or permanent
Authentication: Normal
Security: Off
Port number: 9201.
2) Picture messaging settings:
Data Bearer: PR
Access Point Node (AP): payandgo.o2.co.uk
User ID: paying
Password: password
Gateway: 193.113.200.195
MS Message Server: http://mmsc.mms.02.co.uk:8002
Session Mode: Permanent.
Them. ^ I'm now confused as to where I enter them. I have the Sony Ericsson Xperia Mini Pro.
settings -> wireless & networks -> mobile networks -> access point names -> MENU -> add New
Internet Settings:
Username: paying
Password: password
Security: Off
Port number: 9201.
MENU -> Save
MENU -> add New
Data Bearer: PR
User ID: paying
Password: password
MENU -> save
Don't forget to mark Correct & Helpful Answers
Internet Settings:
Username: paying
Password: password
Security: Off
Port number: 9201.
MENU -> Save
MENU -> add New
Data Bearer: PR
User ID: paying
Password: password
MENU -> save
For future reference
Make sure you backup everything
Settings -> privacy -> Back up my data and Automatic restore should be selected
and also
Use one of these links to download the
Backup & Restore app
http://forum.xda-developers.com/showthread.php?t=1193802
or
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apk
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apkor
http://www.mediafire.com/?1n07llajeaoo03y
How to install it
You need to
go to settings -> applications -> check unknown sources
download IO File Manager
https://market.android.com/details?id=org.openintents.filemanager&feature=search_result
download the backup & restore app, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
Contacts
just to play it safe sync your contacts w/ google if you haven't already
open your phonebook
press MENU button -> tap on Send Contacts -> select all -> send it to your email
on your computer
-> download the file -> go to your gmail -> click on contacts -> click on more actions -> on the drop down menu click on "import" -> choose the file -> and click import
Apps
Don't worry so much about backing up your apps
on your computer go to
market.android.com -> log in -> click on My Library -> and send all your apps to your phone
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
https://market.android.com/details?id=com.zegoggles.smssync&feature=search_result
or your SMS use
"backup & restore SMS"
https://market.android.com/details?id=com.riteshsahu.SMSBackupRestore&feature=search_result
or for your MMS use "Save MMS"
https://market.android.com/details?id=com.schwimmer.android.mmsextract&feature=search_result
Call Logs
And for call logs this is great
https://market.android.com/details?id=com.yang.android.ansta
An easier way to install the Backup & Restore app
download the apk on your computer, send it to yourself through email, make sure you send it to your Gmail
now on your phone
wait for the email, once you get the email, open it, and instead of downloading the attachment it will allow you to install it, voila, done
or
