Hi This is manikandan. recenly i am facing an issues with my XPERIA MINI phone. A default sound is playing automatically , i dont know how to off or stop that. every time i watn to reset my phone or restart my phone , it will be for 20 mins. After that again this problem is coming.. please help me for this....
this is my mail id [email protected]
Hello Henke, after update that sound is gone, but now my moble is slow. the desktop icons are loading slow.. its updated version i have repaired. can u plz tell me how can make my mobel back to normal.... plz reply...
It sounds like you are having a Sony Ericsson Xperia X10 mini, could that be the case?
If you have Sony Ericsson Xperia X10 mini:
Go to settings, Notification ringtone, change to another notification tone.
If you have Sony Ericsson Xperia Mini:
Go to settings, Sound, Default notification, change to another notification tone.
Also make sure that you have not installed any type of ringtone app which can cause this issue.
Let me know if the problem persists.
What are your thoughts about this forum? Let us know by doing this short survey.
no yaar i tried tht also, its not working. i am using XPERIA MINI, plz tell me how to solve that....
That seems strange, have you tried to do a repair of the phone software?
Click on this link to get Sony PC companion:
http://www.sonymobile.com/gb/tools/pc-companion/
Start PC companion, start "Support Zone", start "Update phone software" and click on "Repair".
Follow the on-screen instructions.
Let me know if you are still having this issue after the repair of the phone software.
henke that sound is coming when i drag the shortcut its not coming and after a couple of mins later it occurs again. k anyway i will try to update and i will tell you whats the problem....
Hello Henke just now only i repaired my sony xperia, i think its k, but theres another problem, unfortuately i forgot to remove my SD card. I installed more applications games in SD card. now there is no app or games in the sd card, which i was installed in sd card. plz help me to get back my app or games... plz reply to this msg as soon as possible....
just redownload the apps/games from the play store
