Hi All,
After upgrade to 2.1 when i am going to "Manage Applications" I am seeing only those apps that I have installed unlike before (1.6) where I could see all the installed apps like google apps, default games etc.
Where can I find these apps (in case I want to clear cache or something like this)??
Thanks
While in Manage Applications page, click Menu (four square) button. This will give you option for sorting and filtering. Click filter and select all to view all the applications.
Thanks a lot...crystal clear now.
