Hi everyone.
Everyone seems very helpful here. I can not work out how to do 2 things.
1. I can not work out how to put my contacts and texts back on my phone sinc the recent upgrade. I have attempted to download apps from other recommendations on here but have not been successful.
2. Also since the update my Wi Fi is also not working correctly. It connects to my Wi Fi however it tells me that i only have limited connectivity.
I am pretty rubbish with htis as i have not been able to do the above from other links. Please can some one do me a massive favour and provide me a step by step?
many many thnks
Chris
Hello, I still have problems with this.
I've tried everything I can think of, I downloaded straight to my phone, I've downloaded on my PC and then transferred to the SD card. I've tried different file managers to install the backup & restore app, but it does not work, when i open the file I tap install, it shows a list of stuff and then asks 'do you want to install this application', I tap install once again, it says installing, but after a second or so it says 'Application not installed' and does not give me the option to try again. I've checked the box for the unknown sources so that can't be the problem. I'm lost here, can you help me?
http://forum.xda-developers.com/showthread.php?t=1193802
http://www.mediafire.com/?78bcyp5alpwy0ok
download these files..this should work..
both are the same so download one by one and see which one works..
