When i press the power Buttom the Screen Backout, but never get locked, even that i use security passowrd, but it never get locked, suddenly this happens, besides having all Contacts un reachable to call, when i receive calls i can see contacts but in phone book Nill (no contacts at all), all of this happened suddenly, SomeBody Heeeeeeeeeeeeelp
let it charge until the LED light its green, then try again the Update Service (w/o the SIM card and the SD Card)
then it could be the battery and/or the usb cable and/or the charger, if you can borrow another charger and usb cable, if the same problem persist it could be either the battery or the usb connector on your X10.
the phone was on 88% but if you leave it on it will drain battery, maybe it was on and the only issue was the LCD so it was on but there was no way to tell. but the whole problem with charging that's something else, the X10i has been plagued with malfunctioning motherboards
I had two power drains with my X10, it was 100% and 2 hours later it was all gone, then the second time from 90 to 2% in 20minutes
i Will go to the shop to try another battry cuz i don't know anyone who have X10 this will be the last time to have SE, this is so shit :smileyangry::smileyangry::smileyangry:
