I'm desperately waiting for ICS update on my LWW. I am new to android and I know its going to be lot more fun to explore android 4.0. Having said that, I'm afraid of LWW's internal memory. Will Android 4.0 work seamlessly with the lowest internal memory available in the phone?
Ok, being a lazy person to move apps regularly to SD card, I have one more question: can I tweak the OS to completely ignore phone's internal memory, create virtual partition on SD card and assign that partition as internal memory of the phone?
Thanks,
Jay
Regarding partition your SD card, yes you can do that
this is how
http://talk.sonymobile.com/message/142158#142158
it will be a bit laggy, the more widgets that you have on your homescreen the slower it will be.
this is how
Thanks for the step-by-step guide to do that, uluwooly! you rock!
I'll surely give it a try.
no problem, once ICS it's available for this phone I'll add it here
http://talk.sonymobile.com/thread/38251
