Hi When i see my RAM on Xperia u i found that free ram is only 200mb and used RAm is 100 mB so totalling only to 300.SO the mobiles has 512 mb ram then what happened to other 200mb ram.Is it the situation to everyone ?
I installed backstab and when tried to play only intro vedio does play and then it automatically quits How can i make it run without quitting abruptly.
Please some one help me
Yes other ram is used by Android and doesnot show up.
Backstab is compatible its just your Ram , Free up some ram and then tru again
If you got time then please visit here:::::::::::::::::
TOP APPS for XPU::::
http://talk.sonymobile.com/thread/58158?tstart=0
Custom Roms::
http://talk.sonymobile.com/thread/56689?tstart=0
If you are rooted then please visit
http://talk.sonymobile.com/thread/56641?tstart=0
http://talk.sonymobile.com/thread/56642?tstart=0
If you want to root:
http://forum.xda-developers.com/showthread.php?t=1886460
Please Mark
Custom Roms::
Please Mark
check the running apps and try to close some which arent required at the moment.
Please mark Correct and Helpful answers and you can also visit my blog at:arnabghosal1989's Blog
