Hello!! Im Wondering whyi cant see my notification lights after the update to JB?? is it normal??
if i have a same question from other post, please tell me so i can remove this,, THANKS!!
i guess it can be modified, sometimes mines flashes blue.
i just don't know how to change it
From the os,it cannot be changed,it needs apps from the playstore i guess,or rooting.But it cannot be sure that the apps will work anyway...mine is also white...
I use the Light Flow app https://play.google.com/store/apps/details?id=com.rageconsulting.android.lightflowlite to change led colours and notifications sounds. It works also on JB
let me try this, thanks bro! is this working on stamina mode?
Nope, unfortunately LED do not work (yet) on stamina mode.
