Hi. I want to ask.
When my Xperia Mini Pro receives incoming calls, or whatsapp notification,
my LED notification flashes like...100 or 1000 times per second. I didn't count, but you get the idea of how fast it's going. After the notification tone or ringtone, it goes back to normal, green, flashing like 1 per second or 2 seconds once (didn't time it too, but bottom line, normal flashing rate).
And the colour is something like between white and purple, while the notification tone or ringtone is played.
I couldn't remember my previous xperia x10 mini acting like this.
I want to ask, is this even normal for all mini pro models?
Edit: I can't post the video on it, because in the video, with 24 or 30 fps, you can't see the "100 flashes per second". Also the color in video looks just normal white, nothing mix white with purple due to camera color.
Thanks in advance.
hey hey...
i think its normal
i have xperia arc and i get 100 flashes in a second
too...
its normal..
uliwooly , i get the same thing..
tge color is cyan i think..
Just tell ne whether it's normal in 2.3.4 SE Xperia firmware or mini pro or not?
that doesn't seem normal do you have a taskiller? do you have another app that can changes or mod the LED notification settigs ?
if it's not normal than i'll have to send it back to service centre.
I've tried reset factory data, repair via PC Companian, still same result.
No, I don't have another app that can changes or mod the LED notification settings before this.
But I've tried to download the apps, see if i can change it, still remain same.
Looks so much like hardware issue to me. But I have to send it to check to be sure.
the LED it's supposed to flash when you make a call but not repeatedly
er..
what i mean is during the incoming calls / incoming notification, *during* the music is playing.
yeah probably a hardware problem
i see. well, thanks for replying.
i see you reply in a lot of threads. you really are helpful in this forum.
by the way, how is it supposed to act during the incoming calls? what is colour that it is supposed to be?
