Hey, I have been experiencing laging issues from last few days in my Arc S π
Contacts take about 5 to 8 secs to open up, and same is the case with the dial pad π
Got ICS 4.0.3
Please HELP!!
And how to do that?
Thanks for the dialer app though :smileygrin:
same link above to manually update, you can manually downgrade or you can take your phone to a sony service center and they will downgrade it for you
Oh
Thanks a lot.
Last thing app killers and anti virus free your ram, then why they are not worth it?
they don't free up your RAM they are running in the background wasting battery and creating issues with other apps and with Android itself. taskillers for example, if you kill an app it will drain more battery to restart it than letting be in the background, and now with ICS you don't have to kill them at all, you can disable them. antivirus will create issues with your network and other apps, you don't need it, this is android not a pc
Awsome, Thanks a lot Bro :smileygrin:
anytime, let me know if you need any more help or start a new thread
Sure
NaznaΔite sviΔanje na Facebooku
