Is there any way for me to take the vibration of when I type a text? :S
Try this instead,
Messaging > New Message > tap the picture on the keyboard that looks like a wrench or spanner > untick Vibrate on keypress.
To remove vibration do the following,
Menu > Settings > Language & Keyboard > International Keyboard > Untick vibration on keypress.
but i dont see international keyboard though:S i see chinese keyboard and japanese keyboard:s
Then this would mean you are using one of those 2 keyboards, select the one you currently use and follow the same steps.
my my key press vibration is untick:s
thank you sooo muchhh
No problem, I am glad I could help
it worked 4 me tnx
