My Xperia U keeps rebooting. I can't seem to find it in the SUS.
I can't access the safe mode (volume down + power button gives a green light) long enough to do anything (since it keeps rebooting). My battery is fully charged.
Volume up and power button gives a blue light, but he keeps rebooting after the 'XPERIA' message.
Any suggestions as for what else I can do?
Kind regards,
Jeroen
Hi there,
Repair your phone with PC Companion.
Here is a detailed instruction:
NOTE: Make sure that your phone is completely turned off and follow the recommended steps!
Cheers.
Hi there,
Cheers.
You can use sony update service to repair if the battery is 100% charged.If you want to enter safe mode,at the xperia logo screen,just tap menu key.
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008#U348008
Thanks! My xperia still keeps rebooting whenever I try to connect to wifi..
But now I can at least still use my phone
Have you repaired?If you need to see all models in SUS,run in compatibility mode for windows 7.
Hello, i have the same problem, did you solve your issue? Can you help me if you did. Thanks
I tried the guides mentionned in the subs. Even though my phone still wont do annything else than reboot.
PLZ!!! help me, i need my phone for work and i´m in trouble if my data is lost
