I am trying to connect my xperia mini pro to pc by usb.
I regularly did this prior to updating to androd 2.4.4 latest baseband version .....-64 (i previouly had 58 i think) a few days ago
When i connect , the phone will charge , but the phone is not 'found' by the pc.
i have tried it on several laptops with different cables and usb ports ,
two of these laptops have pc companion installed on them,
a third laptop a sony - does not
but pc companion option to install does not appear
i have tried both connection modes
MTP and MSC
I have tried usb debugging on & off
any advice?
Hi
The phone connects in MTP mode and Windows drivers for MTP comes with the updates for Windows Media Player. Make sure you have the latest update
Check
http://talk.sonymobile.com/thread/34757 and http://talk.sonymobile.com/thread/34042
Hi
Check
