hi,
i want to know the deatails regarding the video playing & compatible files that has been asociated with cedar and also i want to know the charging time required for the phone.......plz help me ...plz any one.......
Both internet and Youtube access & performance are dependent on the speed of the mobile network that you're using.At the moment, I cannot play Youtube videos on my W995 via 3G (T-mobile) because it appears that my network doesn't support the new flash version on which it's running, although it's not a problem over WiFi. In some cases, accessing Youtube may also depend on the phone's customisation and/or the location that you're in.
http://developer.sonyericsson.com/wportal/devworld/phones/phone-overview/cedar?cc=gb&lc=en See under Audio & video for compatible file formats.
Yes, video should play in landscape and battery charging time from flat to full is about 2 and a half hours.
one more thing i wud like to know is whether the internet acessing via cedar is good or not?also whatz the performance of youtube application in cedar?
In several countries, as example in italy, (and using some carriers like tre or fastweb), youtube on cedar simply does not work at all, only black screens.
