As you can see,there is two greyish strip on the LED Strip.It looks like a void tape.Or is it?
*Screenshot of PhoneArena Review.Look at it very closely
Do everyone have those?Also,how to remove it?
That is normal as everybody has said. That's part of internal circuit, most probably to supply signal/power to strip.
upload the picture to box.com and post the link, as we can't see the picture
Its normal...
It takes some time before uploaded pictures are shown
Probably...Thanks for the info!
