I recently updated my xperia T to Jelly Bean I think it was (the last recommended software update) and since then the internal memory (of which there should be approx. 10GB available) is not all available. When I look at the storage section in settings it sais there is 10.85GB available, then there are approx 3GB of pictures and the rest of the sections are all under 1GB, and don't add up to the remaining approx. 7GB that should be free. The section that sais how much space is free only sais about 500MB and I'm getting a message saying my internal storage is 100% full and I should transfer data to an SD card (which I don't have/need). Have you any idea how I can get to use the rest of this space? Before the last update I was able to use it all & since then I've had this problem.
Would really appreciate some help on this!
Thanks in advance,
Bill
I'm also having same problem in my Xperia P (4.0.4). I am waiting for JB update for it and you have already updated to JB and facing this issue:smileyshocked: Try repairing your phone using PC Companion or SUS. Before that try a factory reset.
Yes a factory reset has actually solved the problem! thanks very much for the help!
dont forget to mark the Correct Answer
