Hi
Can I install something from android market via PC?
I mean, I used USB to connect x8 with PC, then I install what I select from the PC to x8
Can I do it?
thanks for your help
hey honeybee
u can only select to install apps from pc but the downloading has to take place through mobile only
when u surf android market, from there u can choose any app and to install it select "install', then that particular app will automatically be downloaded to ur mobile if it has active internet connection
but u cannot download it to ur pc by any means and shift it to x8 using usb
regards
nabeel
hey honeybee
regards
nabeel
Hi
thanks a lot for your attention
