Recently, after i take picture(s), the screen will prompt me to "Insert Memory Card"... After i off & on and inserted the SD card, take 1 or 2 picture(s), it will prompt me again. Then, watever picture(s) (the latest one) was not saved... I can only view all the old pictures only.
Next, when i deleted all the pictures in the album, they will still appear again after i off & on the phone... Tried deleted them from the Media Go but still after off & on, they will appear again...
Please help... Many Many Thanks in advance
Shine
Hi azy123,
I think the memory card is corrupted...
I tried to format the memory card by using the card reader but unable to detect card... Tried insert other card, can read... So i decided to buy a new sd card and now my phone works perfectly well!!!
I guess you have to get a new sd card..:smileygrin:. Good Luck...
thank you shine, yes i guess thats the best i should do. i have tried everything i can do with this but same results happened. just home i can buy a non-corrupted one
