I've just got the new Xperia T and am very happy with it generall BUT the in call volume is horrendous, I had it turned up to the highest possible and the person on the other end still sounded so quiet that I could barely hear them, is this something that can be fixed??
If the earspeaker volume is at max and you still find it low I suggest that you take it to a retailer or repair center to compare your phone with another Xperia T to check if any difference can be noticed. If yes you should have your phone fixed at an repair center.
http://www.sonymobile.com/global-en/support/contact-us/contact-info/
