Please someone tell me, When my phone battery is low (xperia sp) my notification bar blinks Red every 3 seconds.
how can i disable it?
Thanks in advance.
You can not, that's letting you know that your battery its quite low
Don't forget to give Kudos
Ok bro. thank you.
Anytime
What I dont like is the way it all closes down stuff because battery is running low, like back light, also switches of other items,blue tooth etc, I know its to save on battery power but I'd rather just have all the stuff working and charge it when it has run out, it also needs charged up everyday.
Anyone else experience this, I know one of my daughter in laws does.
Maureen.
Smartphones have to be charged everyday, that's a given, unless you hardly ever use the phone and you don't sync it.
