is der any way to switch off the light coming out of the bar below to save battery when needed???
Install the App called "Night Mode"
In its settings, Activate Check mark "Disable Button Backlight"...
It works buddy.. I am using it.
Happy Googling
- Vinopall
there is an app called 'XSLights'. you can try
not finding it..
this may be non play store app. search for LED illumination bar control
night mode.
search in store.
ok...
dat doesn t work fr illumination bar ..
worked for me
my phone went off when i pressed start button n had to restart...
there's also an app called screen filter, its main use is to dim the screen, but if you untick 'enable soft-key backlight' it will turn off the illumination bar
I noticed it will come on again if the battery is low - which is really strange, but ok :smileygrin:
