I Started ICS update for Neo V, but from one and half hour it got stuck at Preparing computer for software update.
and by using update service i get S1Boot download driver problem. Driver installation failed.
What is S1Boot download???
Its there in the list of SUS... look closely
or try this newer SUS
Now, my update stuck a bit ahead of where yours had stuck, from past 3 hours
Please, gimme a solution. I watched this system in my friend's LWW. And I want it. 😕
Hey dude, I think, yours is the best way to do it. My updating through PC companion stuck 4th time in past 2 days.
and I wanted to ask you...
My system apps, data on SD card and my gmail ID setup will vanish using update service? or They will be as it is after updating to ICS from gingerbread of my SE LWW.
and What if internet connection breaks while updating or some kind of disturbance occurs while doing updation through update service? :smileymischief:
turn your firewall and / or antivirus off
Hi Mayur, only phone date will be completed erase when you use Update Service, SD card is not affected. As for disconnection of internet during phone update, no problem .... just repeat the process again. Anyway .... a better solution is to find a reliable internet connection. :smileymischief:
Yeah. I couldn't help myself from waiting to use ICS and updated it through update service and used option 'factory reset+update'. (factory reset erased all phone memory).
and My connection got disconnected thrice & I was happy to know that I could continue from where I was interrupted. and later I fell asleep and when I woke up. I was having ICS :smileygrin:
Update Service is better than PC companion.
Thanks dudes
And thanks Android and Sony.
No problem .... Glad that your phone is updated!
help..... im about to do a repair for my xperia u as per the advice from contact center and now im stuck w/ preparing computer w/ software update.... what to do? plsssss
Don't panic .... just re-do the process.
If you are having problem with PC Companion, try Sony Update Service. Here's the download link, http://www.sonymobile.com/gb/tools/update-service/.
will sony update do the fix for my prob w./ the camera for my xperia u because there a violet light on my camera
