Thanks sony for the update. Am loving my phone more than it was on GB. Just started exploring it as of now am not facing any problems. Even is much faster than GB and no lags at all. Battery is also running better now. Thanks a lot. Love you sony.
Thanks for sharing your thoughts with us. We appreciate your opinion!
same here
probably the only you active Sony xperia update! Sony What is it?
I have some problem while moving on screen to screen as it strucks sometimes with half of both pages. How can this be fixed.
Message was edited by: Bheemad
u might have too many apps in ur phone memory use link2sd app to transfer ur apps to sd card
Hey so should i uninstall all the apps that are lnked to to sd card. But you know that i just have 420 mb of internal storage in which all goolgle apps will occupy mae than 150Mb and what can i use for games and other apps.
no dont uninstall
u can directly transfer the apps from phone memory to sd card
https://play.google.com/store/apps/details?id=com.buak.Link2SD&hl=en
using the software u can directly install apps on to ur card
Am currently using App2SD and with this am installing all in SD whch ever is compatable.
But my phone hangs for few seconds whenever i go to home while using some linked apps.
https://play.google.com/store/apps/details?id=com.a0soft.gphone.app2sd&feature=related_apps
