i have arc, and in the sounds menu all the sound options are unticked but while using touchscreen i cant get rid of sounds like waterdrops or increasing decreasing signal soundsss, terrible.....help
thanks a lot i have been using galaxy nexus for 4 months i have never looked at talkback options, my brothers xperia arc update come with talkback options on, thanks for the info :))))
anytime, don't forget to check this out
Xperia S Music App 4.0.4 leaked, does it work with your Xperia?
http://talk.sonymobile.com/thread/38259
