after each update Sony gives for Xperia P we face some new bugs..so wanted to know if its safe to update to ICS ? because im still struggling with network issues on my phone.
itz a fairly stable build !! the only issue guys have faced is that the screen stiops at the first boot cause some apps migght not be customized !! i advice u too do a factory reset before updating !! no prob reported as of now
and what about network issues ? is it still der ?
none till now that i have faced
thanks!
go for it ITS NOW OR NEVER.....now ICS on xperia p rocks very smooth better battery backup smooth transistions and no glithches in software ........1 and only 1 drawback is the powersaver app is misssing....
the power saver app wont be necessary in ICS I guess.. it already comes with an extended battery standby mode and it automatically kills unwnted applications etc.. I am sure ICS must be having something better than power saver app.
