احتاج الي تغيير موقع التنزيل الافتراضي الي الذاكرة sd
I need to change the default download location to SD memory
-GT
Hi @wab2, welcome to our forum!
Your question has been translated to English as this is an International forum.
Which device are you using? That way I can move the post to the correct board on our forum and give you a more detailed answer.
In certain applications you can set the default storage to the SD card, however this is entirely up to developer of the application, but you can't for example download applications directly to the SD card.
Let me know which device you have and exactly what you want to do and I'll do my best to assist you.
My phone is T2 Sony
Hello again @wab2!
As I wrote in my earlier post, there are no settings to change the default download location of apps and so on to the SD card instead of the internal storage. If you go to Settings > Apps > tap on an app, check if there is an option to move this application to your SD card.
That way you can free up space on the internal storage.
