hye there ,
my girlfriend using nokia 5800 express music.
using my experia ray how to video call with her ??
GTalk is pre-installed in Android phone, therefore you do not need to download it from anywhere. Have a look inside the App Drawer.
Hi, what do you mean by '3g with her'?
i mean video call
Unfortunately your Ray does not support 3G video call. However, you can do it through data with apps such as Skype or GTalk.
how to download gtalk ?
and support for nokia 5800 ?
where cn i get it
thk you so much , ive found for nokia erm and then where cn i get it for my ray ?ive looked at google play and i was confusing which should i download. can you give a link
thnk you, my problem has been solved
Great!
