Hello All,
As we all know there a bit slight issue as far as the internal memory of Xperia Arc is concernend.. when I googled on how can we use our SD card to actually increase the internal memory so that we need not move the apps explicitly to the SD card, I came to knw that we need to create a partition on our SD card in ext4 format.. But I dint get the exact way of doing it... so can anybody tell me how we can do it? And does it need to have a custom ROM installed? Does it work on stock ROM also? Please help.. Thanks..
did you checked that?
Hey Uli,
Thanks alot mate.. I had checked that thread but didnt check it thourughly.. I just wanna know, do I need to flash my rom with some other custom ROM? or this will work on stock ROM (Rooted)??
its for stock ROM and it must be rooted
Hey Uli,
As always... Thanks alot for ur help!!!
Cheers!!
Anytime, just remember to backup EVERYTHING
