Hello!
I have updated my Sony Ericsson Xperia Neo to Android version 2.3.4, build number 4.0.2.A.0.62. How can I uninstall this update so that I get back build number 4.0.2.A.0.42 or Android version 2.3.3 ?
I made a factory reset, but it did not turn out the way I wanted it. Pls help.
Thanks in advance.
Hi, there is no way to downgrade firmware the official way.
you can downgrade but as gwhispererz said " you cannot do it the official way"
there is an unoffiical way but you may lose warranty...
Thanks for the info! How do I uninstall unofficially? I don't think I have a warranty and I don't care about it so much.
I really want to root my phone and get rid of many stupid applications. On 42 it was possible, why did I have to upgrade to 64?!?
I'd do anything,just don't know how to downgrade.
do you have xperia pro or neo v..??
Hi!
My phone is Xperia Neo, without V or Pro or anything else.
i have asked some other member to help you , he'll reply you soon.
thanks uli
Anytime
