I have had this problem since updating to the latest update. Everytime I switch my phone off and then switch back it automatically tries to connect to wi-fi. Even if I disable the wi-fi after 10 minutes it will switch itself back on and again It is starting to get annoying now as I needed to use my phone on Friday and the battery on my phone was dead.
I have only had this phone for a month and I am coming to the conclusion it is the worst phone that I have got on contract and really hate using it. I have had problems with wi-fi and lose of that, Losing phone calls and calls been dropped. Mobile data losing that. I also have a iPhone 3GS and even changed the sim card with a holder over to that phone and used that and the sim card was not the problem.
Go to battery settings and disable last option (if available) "Location Based Wifi"
You rock man! Thanks!
hey this option worked...!! thanks!!
i just fail to understand why the WiFi option is present in battery settings????
would'nt keeping it in WiFi settings be nice, user friendly and logical??????
Slide down from top down to access the hot-keys;
1: Press and hold the Wi-Fi icon.
2: Under Wi-Fi preferences, disable "Turn on Wi-Fi automatically"
Hope the above helped.
The Xperia lx keeps switching on
how do I stop it
The phone switches itself on whenever I have the Internet connected.
How do I stop it switching itself on apart from switching off the Wi-Fi
model XpeiaL1
