Here my facbook, whatsup, viber apps automatically opens in running apps though i dont use mobile data. How could i stop it and save the charge??? please find me a solution for this.
if you don't use those apps there shouldn't be an issue, you can re-enable them anytime
settings > apps > scroll to the bottom
unrelated topic, if you have some time please check this thread
do NOT use taskillers or battery apps, this will create a lot of issues and drain your battery.
if you don't use the apps just disable them, as you can read on the permissions (play.google.com look for the app) this apps might be triggered by other apps.
uliwooly: Please could you say me " how i could disable the apps???" there no options show in permissions.
Please give a step by step solution to solve this.
settings > apps > all > look for the app > disable
Im using Xperia tipo,
if i use disble option its shows that
"if you disable a built-in app, other apps may misbehave."
will any problem will come by disabling it????
uliwooly: If i once uninstalled the any apps could i install it again???
And how can i enable the disabled apps again???
The disable apps are shown at the bottom but the uninstalled apps are not shown!!! where i can get the apps again????
Can i make a backup for the uninstalled apps ?? because if it could its esy to install again without dowloading each and every time.
And i can disable only the in-built apps but i cannot disable the downloaded apps, for the downloaded apps there is the only option to "uninstall" !!!!!!!!!
to re-enable them
settings > apps > scroll to the bottom > select the app > enable
you can re-install the apps from the market play.google.com
mcafee it's a preloaded app that you don't need, if you uninstall it and you want it back just repair your phone with SUS or PCC and it will restore the app
taskillers, antivirus, battery apps, ram apps are not a good idea at all
http://talk.sonymobile.com/message/244522#244522
Will any problem will come if i use "Force Stop" option ?????
