Hey,
If I root my Xperia arc s and uninstall Facebook using Titanium backup, and then reinstall it using the Play Store, will this stop it starting on boot?
Thanks.
lol
which apps did you disable? (it's easier if you take a screenshot settings > apps > all > scroll to the bottom)
unrelated topic, if you have some time please check this thread
I disabled all that I could:
Facebook calender sync
Facebook extension
Facebook setup
FBiX Music Likes
FBiX Post Viewer
FBiX Proxy
how about recommender?
I don't have that...
hello.. what is this recommender app? I've googled it and found nothing. Is this really needed?
