I found few unused/irrlevant applications loaded in the mobile. Few of these applications starts as default processes and keeps running in the background. If the applications are not part of core operating system and not required to always keep in mobile, should be allowed to remove them.
Few of them are:
Please let me know how to remove these apps and release resources to allocate/divert/use it for other required applications.
Thanks in advance,
Nilesh
These apps couldn't be removed unfortunately
You need to root your mobile in order to do that... and that would void your warranty
