my phone has started working after many days thanks to some response from the support forum but it still says that it is on safe mode and hence i am not able to access all my applications.....can someone please help???
Hi ntinibali,
Welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
You should be able to simply turn the handset off and then power it on normally. Make sure you are not holding the Volume down key when performing this task.
Also if you are using a case, you may need to remove it then try turning the device on.
I hope this helps.
@ntinibali,
Can you confirm that your "Volume Down" is working properly?
yes my volume down button works fine
Try force shutdown...open back cover push and hold off button until phone vibrate 3times..then turn it on normally
