I had been pull the plastic strip in the sd-card port, how to pull back them?
Hi @Risman_Budhi,
I'm not quite sure I understand your question, but you if you check in the manual you can see exactly how to remove a Micro-SD card from your device. You can find in here, check the assembly section (page 😎 and you will find how to insert and remove a Micro-SD card.
Let me know if this answers your question.
