I've looked on my phone everywhere, I've looked all over the fourms... I used the companion hoping i could find something. But I can not figure out how to connect to my computer using MTP mode. Can someone please help me?
if its to update your phone try
Update Service
http://dl-www.sonyericsson.com/cws/download/1/110/61/1315209439/Update_Service_Setup-2.11.9.6.exe
settings -> sony ericsson -> connectivity -> USB connection mode -> MTP mode
Can you try to go to the Settings menu ---> Connectivity settings ---> USB connection mode ---> Media transfer mode (MTP)
Just saw uliwooly has responded.
I don't see sony ericsson in the settings.
let me guess, you have the verizon xperia play
yes i do.
That a problem?
