How do i enable sony cloud storage & from where can i check the space allocated
regards,
you have to register with Box and also if you don't have the app you have to download "Box" from the play store
Its currently showing 5 GB storage, how do i claim sonys 50Gb offer
regards,
once you use your Xperia it should enable 50GB I don't know if the deal is still good but you can check the website regarding that
