Hi i want to disable vibrating while typing. How to disable the vibrate?
See if you're able to make it in Sola
Here in Xperia SL , it's this path
Settings > LANGUAGE AND INPUT > Tap on the settings icon next to Xperia Keyboard > Sound and Vibration
Thanks dude it helped
Go to Settings - Language & Input - XperiaTM keyboard - Keypress feedback - and turn off Vibration on Keypress
