I would like to knw how to deactivate vibration feedback in call dial....
it cannot be turned off..
u may download any new dialer from the android market and see if you get one application which suits you
i have the same problem with my xperia mini pro when dialling phone # and as per Aimee of SE, it is normail and can not be turn OFF.
yeahh.. we have the same problem .,.. i wish to deacticate the vibrating mode while typing the dial key.. but unfortunately i can not found the settings which can stop the said effect..
there is also a vibraTION effect while setting some wallpaper on the main screen and etc.. but i cannot found the setting that will stop it...hope there will be some application on the market that will stop the vibration....
wish there will be one??!!! >,.,<</p>
as i said for the dialer there are many applications..
just search it and see..
