Hello guyz
when i used android 2.3.4 i can access slide lock and pattern lock simultaneously after updating to ICS it dint work so i used onlt pattern again i upated to latest firmware in my xperia live with walman on a day some time i can access slide and pattern else my LWW shows only pattern to unlock
something problem
plz expalin me How to access slide lock and pattern lock simultaneously
here are some apps
WidgetLocker
ICS Lockscreen HD
unrelated topic, if you have some time please check this thread
you can't then only option is to add a third party lockscreen
thanxz fr u reply
but daily once at any time in my mobile i can suddenly slide lock+pattern
i want it all the time fr that plz update frimware with debugs
it's not a bug, if you think about it, it's pointless to have a pin lock and a slide lock, if it's to access the camera just long press the shutter and that should do it
here are some apps
WidgetLocker
ICS Lockscreen HD
Although my problem wasn't the same, I have just found out thru this discussion why my Slider changed - Go Locker - and have uninstalled it.
Thanks!
