please,
help me
how remove a virus in internal memory of android phone..
my android phOne is affected of Virus,
my installd apps is from google play.
use malwarebytes or avast for android
If you got the app from the official Google Play store then it shouldn't be malware, Google removes malware asap. It could be an app showing ads regarding a virus on your phone-if so then remove any unknown apps via Settings>Apps. If it is an actual virus (which I doubt) then install an antivirus scanner such as Avast-which is the best for android. Carry out a scan and remove the malicious app-if any.
There might have been an app with ads,they tend to trick the user with some super shiny writing where it says you have virus or your phone is slow.
Hi, i also had a problem same as your's. the malware/adware appears after I unlock my phone of after my lock screen (while i'm connected to WIFI or my mobile data was turned on). I just downloaded Malwarebytes from Google Play Store then run a full scan on my Xperia Z2 then, the Malware has been detected then i just un-installed it. hope to help you with this.
i need help to remove bug virue,my soney expire
How remove a virus in internal memory of Android phone " PLEASE HELP ME"
