i want to get sound while i write on my keyboard but i dont know how
Go to settings>language and input>xperia keyboard>sound and vibration>sound on keypress
I request full and detaile help to answer on phone instruction which says
“ go to THE keyboard “ Q. WHICH IS THE KEYBOARD?.there can be many keyboards.
i request directions point by point how to set sound to ALL keyboards and how to adjust the volume when tapping the keyboard.
thank you
When I go to Languages and Input the following page reads Keyboard & inputs >
On-Screen keyboard > Physical Keyboard > Advanced > spellchecker > Autofill Service (Google)
That is all....nothing about sounds on tapping keyboard.
the process as you describe does not work because my new Xperia XA2 does not follow the path you recommend
