how can i register my Gmail acount through net? without using the phone..?
i have no wifi here.. i cant download on aplications in aplication market it says no phone register....
can you help me about this?
Did you input the same/correct Gmail username that you have just created? If you have, suggest power off and on your phone and try again.
Hi, visit http://www.google.com with your PC/Laptop, then click Gmail. You can create an account there.
i try to log in it in android market it wont allow me to click the install
telling me
